suave6565
- February 2, 2005
- Brooklyn,NY
- 1996 Ford Explorer
I have a 1996 Ford Explorer EB. My Truck has the original factory radio,amp and sub. I am new at this and i want to do this this right way without going overboard. I've been checking out the site, and have seen some pretty good installs and have loved the site for being so informative!! Because of the money situation, i can only upgrade a little at a time, so i want to do this without completely loosing my tunes.
What i like to do first, is replace the my factor JBL radio and replace it with a Dual Din radio that has DVD player and a nice size screen or i can go with single din and get the trim kit...As for the Dual Din, i've only seen custom work to have these radio installed. from what i understand, there maybe some cutting involved to make the dual din fit.any suggestions??
now i have a few questions:
If i should choose any radio, i still have the issue with the 6 CD changer. i would like to replace the existing one and install it with a new changer that can fit in the same spot as the original. is this possible or should be looking at the my center console with more space?
what is a wire harness??? I've seen this term thrown around and thought i might ask here then do a search on the web and get tons o definitions. is this something that makes wiring radios easy? Like an adpater??
I've seen pre-made sub box, i believe come with its own amp, is this the right way to go? my current one suck, this is my second one I've replaced, then again I'm getting what i pay for 20 bucks...
now for the amp... I'm assuming i have to change it at some point...any suggestions a good but cheap one...
The reason I'm these questions and has put my project on hold, its because I've heard its real pain to upgrade from a factory radio to after market on these trucks.
I need help...
Thanks in advance
I need help...
Thanks in advance
