Hi Everyone,
I read the problem described many times online but I couldn't find a description of the diagnostic:
Let me use other people words to describe the problem:
"I have a ford explorer 1996, it always start in the morning, but after driving for a 10 min. and try to start a gain one or two hours lates, it won't star, only cranks, and smells gasoline, after six or seven times in two minutes it's star like with no problem, I have changed the Air Control Valve, and it's has the same problem? What could it be,, any one Knows???"
It seems to be related with the temperature:
- It start fine when the engine is cold.
- It start fine if the engine is turned off and restarted immediately before the temperature drops.
- It doesn't start if the engine is turned off for a while and the temperature dropped slightly. Then, the engine will start only if the gauge reach the cold area. It looks like there is no fuel supplied.
I shouldn't be related to the 00M12: wrong year and 00M12 doesn't start when cold...
It is not the idle air control valve (IAC), I changed it and it doesn't make any difference.
The car is a 1996 sport 4.0L EFI 4WD.
I suspect a sensor, could it be the air sensor, since the car cool down relatively fast (30 minutes)?
Does anyone know the answer to that dilemma.
Thx for your help
JB
