1996 transfer case problem | Ford Explorer Forums
cecil123
1996 Explorer
transfer case sounds like it is slipping and grinding when it is in 4 wheel drive low and high. This is a 1996 4.0 Explorer.
I moved your thread into our transmission and transfercase subforum.
At the beginning of this video you can hear a ratcheting sound when he's trying to climb the stump. Is that what you hear or is it different?
This is the discussion thread for the video above:
http://www.explorerforum.com/forums/showthread.php?t=352480
Your range hub is bad along with fork and more than likely the case has wear in the bore for shift fork rod.
