I'm having the same issue, replaced the motor the first tim then starter the second bc the first starter was for a 97 so I used the motor off of it. Then replaced the whole starter and it's under warranty still. Had someone help me before and guided it on the top bolt thru the wheel well and they used an extension and swivel from above. now im doing it solo and having a hard time getting to the top bolt again. Tried going under and I don't have much room to move the ratchet and keep the socket from coming off while applying pressure. It's the right size socket just awkward angle.
I have a 95, I had the Same problem, the first time.
now 2nd & 3rd time, less than 45 mins.
Tools, stanley tools make a ratchet, that you spin the handle and the head turns. And ratcheting wrenches. I also have adapter you can add to your socket, too use the ratcheting wrenches on sockets.
1. Disconnect positive terminal on battery.
2. Remove the two starter bolts.
3. Than pull the starter out and turn it up. Nose facing up.
4. then Disconnect the positive cable nut on starter.
Than slip it through between the exhaust pipe and engine. Its out..
