1996 XLT Rear Door Replacement? | Ford Explorer Forums
Spartan
Sun Prairie WI
1996 XLT, 5.0 2WD
Alright gents, i have a couple of questions:
I need to replace the door on my 1996 xlt. I have a full replacement door sitting here, but I am unsure of the electrical connections. Looking at the replacement door, which (I THINK) is from a 1996 (its definitely a second gen) it looks like there is a single plug for the entire door harness, on the BODY side, just on the other side of the black rubber accordian/coduit. Is this correct? The door has the same options, power window, power lock, same lighting. I am just hoping i can undo the connector and unbolt the door for replacement.
I guess what I'm really asking is.... is there a single connector on the body side door harness?
TIA
There SHOULD BE a single connector. Meaning, that is how 90% of them are done. Note I didn't say 100%.
It is easy to pull the boot or remove the B-pillar trim and get a look-see in there.
