wcsd106
- October 3, 2016
- Marion, Illinois
- 1997 Ford Explorer XLT
- Callsign
- KB9IOU
Hello All.
Now that I have my 1997 explorer XLT starting reliably, it is time to move on to the second item on my priorities list... Getting the four wheel drive to engage.
Here's what I have so far.
I've been doing some reading and will continue to do so while I await responses. Thanks again for all your help.
- With the front tires jacked up off the ground, I was able to turn both wheel and observed the front driveshaft turning.
- Prior to starting the vehicle, the 4x4 and 4LO lights illuminate during the lamp test.
- Turning the control trac switch from 4Auto to 4HIGH or 4LOW prior to starting the engine or while the engine is running has no effect, whether the vehicle is in park or neutral.
- Regardless of switch position, no clicks or indicator lights are observed
- All fuses in the drivers side panel and the power distribution box test good with a multimeter. I did a visual inspection of all fuses related to 4wd for good measure.
