CarMama
- June 29, 2014
- Myrtle Beach, South Carolina
- 2006 Dodge Grand Caravan
I have a problem that I just can't seem to find a solution to. I have had a 1998 Ford Explorer that someone tried to replace the heated mirror on the drivers side door sitting in my garage since July. Problem is he didn't disconnect the battery and he FRIED the headlight and dimmer switches. Then, someone else decided to rewire them, didn't disconnect the battery, and neglected to check to see if there was a fuse in the corresponding slot. There wasn't, and it totally Toasted random wires all through the interior wiring harness and destroyed the interior relay box.
I found a wiring harness that I thought was a fit, only to realize that the old harness had both connectors C232 (Air Bag Diagnostic Monitor and C233 (also labeled Air Bag Diagnostic Monitor), but the new harness only had a different version of the C233 connector, which is called Restraints Control Module.
I have spent months modifying the new harness to be an exact match of the old one and am now ready to install it and get the darned dashboard out of my living room (did I mention that?) but I have run into yet another problem. There are burnt wires in the wiring harness going from the inside of the truck to the boot connector in the door jamb and also burnt wires inside the door itself.
I got the connector (C245) in the door jamb apart and can fix the issue coming FROM the truck interior, but for the life of me cannot figure out how to get to the wires coming from the door up into the top of that connector. I thought I could push the boot back through the hole in the door, but I just can't get it to budge. Has anyone ever had to do that before? Even if I take the door off I don't think I can push that connector through there. Any help at all would be appreciated. I tried to post a pic of the connector, but am not really sure how to do that. When I click on insert image it asks for a url...
