mikey7
- April 26, 2023
- Cookeville TN
- 1998 Explorer EB
AFTER WEEKEND UPDATES -
The Trans case (TC) is marked (I was mistaken due to bad light and eyes);
H - 9oclock
N - 6oclock
L - 12
I think this means that this eng (V6) TC (Borg Warner) combo never really has 2WD, as it's the Electromag clutch which engages (front) 4WD. If I had to put a switch on the brown wire, to control 2WD-4WD that is fine. Then I could use the 'TC shift adapter' (if I could find one cheap - junkyard ?) to shift into Hi or Low. I might never use Low anyways.
UPDATE
I had buddy in drivers seat and whil eeng running switching back and forth Auto-4high-4Low and the SM didn't move at all. I really don't care if the SM works as I would rather hook it all up with switches or levers.
UPDATE
I got the TC to shift between High-Nuetral-Low by running the engine and putting the reg tranny in N. The shift shaft is spring loaded to keep the shift forks from getting bent and taking sharp loads off i suspect.
TC CONCERN
I have noticed that the TC shifts REALLY easily, too easily. I can't imagine driving it with the Shift Motor (SM) off, or without the 'adapter kit' which I have little info on.
NO 1st or 2nd ?
Also, it seems right at the time I took off the TC SM, the regular tranny won't start out in 1 (then 2 then 3) but now starts off in 3. Could this be because of the TC's Speed Sensor I have heard about ?
WHERE is the TC's EM clutch plug (brown wire) so I can disconnect it ? Are they part of the group on the SM wires ?
H - 9oclock
N - 6oclock
L - 12
UPDATE
UPDATE
TC CONCERN
NO 1st or 2nd ?
