1998 Explorer XLT AC compressor switch. | Ford Explorer Forums
gooddriver
morgantown,IN
1998 XLT
How do you remove the ac compressor switch? The 2 wires are removed, is there a certain tool to spin the switch out? How do you bypass the switch to test if the switch is bad?
Thanks
Welcome to this forum! I've moved your thread into the A/C & heater section. A box wrench is used to turn the switch. A small piece of wire plugs into the socket to bypass the switch when you want to test the circuit, and refill the system with freon.
I believe there is a valve in the dryer to keep the R134a from escaping.
