dtunget
- January 13, 2006
- Oklahoma City, OK
- 1999 Auto 4x4
Here's the story: We started having an issue about a month ago where our explorer would not go into gear right away from, say, a dead stop at a traffic light, so it's in D, try to take off and the engine just revs for a second then goes into gear. Then this progressed to happening when going from 1st to 2nd gear. So at say, 20mph and under, I'm having the transmission come out of gear and the engine just reving up like it's in neutral. This seems to happen less when the explorer is cold and more frequently when we've driven a few miles. It works just find if I manually go through the gears.
So, I took it to a fairly respectable shop here and had them take a look. Well, you guessed it, it only happens when it's warmed up good and they didn't drive it far enough for it to start messing up. They didn't have any trouble when they drove it, so we just had them service it (no significant findings in the fluid,) and we went on about our way, however, this did nothing to correct our problem and it's only been getting worse.
Edit: Forgot to mention that I really don't know what tranny I have. Is there an easy way to tell from the VIN or something or does auto 4 wheel drive tell you all that you need to know? Also, this problem doesn't happen past 30mph or so. Once it's out of the lower 2 gears it's all good to cruise down the highway or whatever, it's just taking off that's a problem.
Any thoughts or suggestions are appreciated!
