1999 mountaineer codes p171 and p174
mountaineer99
I have a 1999 mountaineer that codes 171 and 174 keep coming up.
I have replaced the oxygen sensor and I have checked the mass air flow sensor. The intake manifold gaskets have been replaced.
I can not find a vacuum leak.
I think I have a bad fuel injector. Is there a way to test them?
need more info 4.0 sohc or 5.0
99 mountaineer 4.0l sohc p171 and p174
I have the 4.0l v6.
the p171 and p174 codes keep popping up.
I have replaced the intake manifold gaskets and o2 sensors
you gotta have a vacuum leak look at pcv system also look around egr pipe going into intake i have seen the pipe bent and not fitting properly into intake you can check with carb cleaner look for rpm changes
Top Bottom
