dwe
- November 25, 2008
- PEI
- 1999 XLT
Hello Everyone,
I have been reading this forum to try to find anyone who has had this type of issue with their Explorer and the closest I found was a similar problem in here that happend to a 2002 XLT, however I am not so confident that my troubles could be resolved with that easy of a solution so if anyone has any thoughts they would be greatly appreciated.
What seems to be happening is that the auto setting isn't completely disengaging from 4hi once switched back to auto from 4hi or 4lo at that matter, I do hear the relays clicking and you can hear the transfer case engage and disengage , however when I accelerate from a complete stop it's almost like it quickly clunks a bit, quite a few times trying to engage the front axles but once up to speed on the highway it seems fine except it feels a little heavier almost like it's trying to pull one way harder then the other (it is aligned properly with all the same tire size), but then when I am slowing again to stop you can hear a wind down noise from the transfer case and then when you accelerate again it clunks a few times again getting up to speed and then stops once up to speed, now it is true, I have three tires worn down more then the new one I had just replaced however the very interesting part is that it comes and goes, yesterday for example I cycled it through the three settings in N from auto to 4hi to 4lo to auto each time putting it back into drive and amazingly it seemed to resolve the problem and worked fine for the remainder of the morning with no pulling no clunks no wind down noises on takeoff or slow down it just felt right again while in auto then I had went back to 4hi as I was doing some work in deep snow then went when I went back into auto the problem had returned again.... I wonder if the three other tire's being worn more then the new one would cause this much clunking and handling issues?? or am I into more serious issues??
I will be hosting it in the morning to see if there are any mechanical or electrical issues that would resolve this and I also I have just read the Brown wire mod (Will likely do that anyway as it would likely be a little easier on fuel)
However any other feedback would be greatly appreciated.
Cheers!
Cheers!
