SteveVB
- July 8, 1999
- Gaithersburg, Maryland
- 04 Rubicon w/stuff
Found an old E-mail from Sven
I found an old e-mail (8/23/00) from Sven about the pushrods and length. I had .010 taken off my heads when the machine shop worked on them, thats why my dimension is different in the order call out compared to the recommendation.
Steve,
Mean length over the full sphere on a stock Ford pushrod is 5.480", which on a stock engine, should give about .045-.055" preload. If you have one of our performance cams, the pushrod length must be increased to 5.550-5,555" to keep the geometery and preload correct provided no other block or head machining has been done. In your case the proper length would be 5.540-5.545" to accomodate the head machining.
If you need pushrods quickly you could have them made by Smith Bros Pushrods (800) 367-1533 to the following dimensions:
Quanity 12
Length (over full sphere) =5.545"
Tubing=5/16 Chrome Moly
Pushrod tips= 5/32 R ball ends(non drilled)
Hope this Helps
Regards
Sven Pruett
Vanir Technologies
Steve,
Quanity 12
Hope this Helps
Regards
Sven Pruett
Vanir Technologies
