1st gen front coil springs into 3rd/4th gen ??? | Ford Explorer Forums
The Electrician
Makkah
2008 XLT 4WD V6
Hi every one
Is it possible to install 1st gen explorer front coil springs into 3rd/4th egn explorer???
I'm thinking of using onr of the following:
  • Superlift coil springs 4" lift #123
  • Skyjacker coil springs 4" lift #134
  • Skyjacker coil springs 6" lift #136
As long as its compatible with the strut, then sure. But if its not compatible with the strut, then there's probably no way to make them work without heavily altering the components.
can any one confirm this info?
or post a picture for both generation's struts
This is a picture of 4th gen struts
The 1st gen Exploreres do not use a strut. They use a shock and a spring. They are not compatible with a 3rd gen.
so is there any choice for stiffer coil-over springs?
I need springs that can hold an extra 250+ lb in front end
Ah I see what you just posted.
Try installing a set of coil spring spacers. They are installed between the sprign and spring seat and pre-compress the spring slightly so that it's stiffer and gives some lift to counter things like winches on the front.
Look at the universal types on www.energysuspension.com
Like Ronin said check coilsprings.com. Give them the ford number and they can fab springs to be stiffer. very good priced too!
