janolsson
- July 6, 2009
- Leicester, UK
- No Ex at the mo
Hi there guys from a cousin across the pond. 1998 4.0L SOHC 5R55E 112K
Recently i have been having the 2-3 flare. I have dropped the pan and replaced the filter and fluid, and whilst the pan was off i torqued all the VB bolts (there were 3 or 4 loose). I have also done the band setting.
After the fluid change the shifts firmed up but the flare was slightly worse ie most 2-3 shifts rather than just 1 in 4. After the band adjust the shifts are now smooth but still getting the flare tho now it is worse when cold but only occasionally once warm.
Now my thoughts are next i should try the VB gasket and/or the epc solenoid.
As i'm in the uk i'd rather not get an updated VB just yet and i'm not sure i'm upto doing the upgrades myself from a kit.
I have read a few threads to get my head around this and i think i may have confused myself a little but i am leaning towards gasket blown or epc struggling.
So my question is two fold;
If i source the updated bonded separater (part number? ) can i use this without upgrading the VB?
Should i do the epc at the same time?
Thanks in advance
Jan
Thanks in advance
Jan
