2.3L Performance/mileage gains | Page 2 | Ford Explorer Forums
That's it, I'm moving back east!!! :D
Well you could do the same thing that I have done to my friends 89 ranger. Build a cold air intake and put on a electric fan. That frees up a few horse power and some torque witch in turns will help on milage. I will take a pic of the cold air that I built for my friends truck tomorrow and post it.
Id appreciate that. I want to do some sort of air intake but i aint paying tons of money for one. I made my own intake for my other truck. Its a 2000 F-250 with a 7.3.
You can get a Magnaflow universal high flow cat for around $60 from Summit Racing.
The OP is in Ohio. He doesn't need to worry about them high dollar Cali approved cats :p:
Yep. They don't even check emissions around here. In the bigger citys they will sometimes. But where im at every vehicle that has had exhaust work done probably doesn't have a cat. Especially all the old trucks guys got around here.
Believe it or not, what oil you use can also make a big difference, on such a small motor. Unless your motor has significant leakage, blowby, or burns oil, I would make sure you use synthetic 5W30,or even 5W20. If you are currently using something "thicker", you will notice an improvement in fuel economy, and you may even feel a slight bit of seat-of-the-pants power improvement.
Also, as someone suggested, a Cold Air Intake setup will also make a noticable improvement. The pre-made/engineered ones, like a K&N FIPK, are the best, but you can make your own that will come pretty close, and be a lot cheaper.
Buy a universal cone shaped, cotton filter of your choice (K&N,Volant, AEM,etc...), then build the tubing with PVC schedule 40 pipe, and rubber couplers from Home Depot or Lowes. Be sure that the filter is able to grab cool outside air as much as possible, and is not sucking in hot under-hood air. Also, for added heat-rejection, wrap the pipe in self-adhesive insulated foam, with the aluminum coating. It's also sold at Home Depot, as pipe wrap, or hot water heater wrap. It's fairly thin, and comes in a roll.
Also, in addition to the hi-flow cat, you can also install an aftermarket, or custom bent exhaust, with SLIGHTLY larger than stock pipes/better flowing muffler/etc... Don't go too big on the pipes though. That little motor needs all the torque it can get.
As for MPG, there a few little things you could do, that might help a bit.
1.) Wheels. If you currently have steel wheels, consider picking up a set of junkyard stcok aluminum wheels. For someting this old, you should be able to find a set of wheels fairly cheap. Remember, a lot of newer wheels will also fit, just watch the center hole size, if you have 4x4, as the hub needs to pass thru. (Jeep wheels, unfortunately, won't fit because of that, even though the bolt pattern is the same.) Don't forget the spare too.
You could easily save 10lbs per wheel. Not only will the static weight reduction help, but wheels are rotating weight, therefor this the most significant place to save weight. The truck will accelerate and break slightly quicker, and may even handle a bit better.
2.) Overall weight. Clean out any crap you don't need to carry. This includes the cab and the bed.
3.) Aerodynamics. If it's a 2wd, you could lower it little, fairly easily. That would reduce drag, at highway speeds. If it's a 4x4, then forget it. Given what the truck is, and your stated goals, it just wouldn't be worth effort.
In addition, you might try building yourself a front lower air dam, to keep some of the air form getting under the truck, at highway speeds.
A bed cover will also help. If you don't want to buy one, you could probably make something. Just be carefull with the materials and construction. It would be counter productive to add a whole bunch of weight.
www.ecomodder.com
http://aerocaps.com/
http://i.autobloggreen.com/2010/01/...cs-truck-owners-get-in-on-the-aero-ecomods-t/
http://ecomodder.com/forum/showthread.php/list-aero-mods-you-can-do-your-vehicle-83.html
If you're really feeling ambitious, you could try to build a complete undertray, to close up/smooth out the underside.
Also, as someone else mentioned, and electric fan, to replace the stock mechanical one,would be a noticeable imporvement in economy, and power.
If there underdrive pullies available for your engine, You should definitely get it/them. By reducing the speed of your engine driven accessories (P/S, a/c, alternator, water pump), it reduces the amount of engine power needed to drive them. On such a small engine, this can amount to a significant percentage of the engine's total power.
www.ecomodder.com
Ill almost definitely do some sort of home made intake. I also want to get a straight through muffler, im sure the one now is a bit restrictive.
Ill check junk yards for aluminum wheels. What years will work? Any? Its a 2wd so hubs aren't an issue.
The only thing in my bed now is a plastic toolbox, my spare tire, and a bunch of beer cans. lol
How would i go about lowering it? Cheap and easy of course. Ill look into the air dam thing.
Im not too worried about underdrive pulleys. Its a base model so it don't have any of the fancy power steering and stuff. The belt runs from the crank, alternator and water pump. thats it.
I just got done putting a straight through cherry bomb glass pack on, 25 bucks. We'll see how that helps the mileage. Seems to have a bit more arse in the low end. Maybe just in my head, who knows. Still pretty quiet. Got a bit more noise which i wanted, im happy with it.
Well I havn't been able to figuer out how to upload pics to the forum. So I saved them to my name on the forum.
http://www.explorerforum.com/forums//album.php?albumid=375
Not bad for a home-made setup. However, a couple of suggestions.
1.) I would try to make a couple of gradual turns, instead of that sharp 90 you've got at the end of the straight piece, going out towards the filter. If you got the angles just right, it would put the filter in the same place where it is now, without the need for that last funky little "switchback" bend just before the filter.
2.) More importantly, I would do something to get the filter supported up off the frame rail. The metal mesh on these filters is very thin. It won't take long to rub through it, and ruin the filter. I would also build a heat shield of some sort, to shield the filter from engine heat.
Thanks for the suggestion. This is a build in progress that's they there is on supports yet. And as for the way it is shaped is to clear the a/c compressor and the battery.
