Minivek
- July 22, 2003
- Quebec, Canada
- '03 Limited Ex silver
Hey there, I'm finally getting around to lifting my ex. I've done my research and now I need some tips from the gurus on here
I'm pretty set on doing a F-150 spring switch (attach 150 leaves to my main leaves) Things is, I have a 1st gen sport
haha, But seriously, how much would the rear end be lifted approximately, they are sagging quite a bit now. I think the sport has like 200 lbs less on the rear end, so that should do something. Also, I read somewhere on here that lifting the truck actually restores some lost stability due to the frame and body's center of gravity being closer together. To what extent is that true? Also between 2" and 4" what are your thoughts, I've got 31's on right now but eventually I'd like to regear to 4.10's with 33's. It's a daily driver and weekend warrior. Also, how would it look with 4" lift and 31? functionnaly and looks wise. Also, what do you suggest for the front, are spacers as good as new coils? can other than explorer coils be used? I going to be fabbing up the radius arm, axle brackets if I go 4"
Thanks a lot everyone. I promise pics and writeups
