not sure how many degrees but timing was off by more than a little bit...139,317 miles.
what "cheap" maintenence do you suggest before i reassemble the engine? i got a new PCV Valve and QD electronic cleaner today, the drive belt and thermostat i could get for $35-40 after i make sure the valves are good, which should be tonight waiting on a buddy to bring the microscope over....
and also do i have to take both valve covers off to time it or can i time each cam "seperately"?
. . . how would i go about putting pressure in the cylinder? i do have an air compressor on hand. Would that be able to tell if the valves were damaged as well or just seated correctly?
139k on those plugs and man that sludge bomb motor is nasty. . .
looks like i will be putting a motor in...scope/probe revealed black substance on top of heads and an interference mark on the cylinder closest to driver.... overheating or no oil maintenence couldve caused the sludge, cylinder walls werent in the best shape either.
