2000 Explorer Rough Idle and Lumpy Engine At Cruise Speeds | Ford Explorer Forums
JNC123
Gastonia, NC
2000 Ford Explorer
My 2000 Explorer was running great but inspection was due. CEL was on and shop said I needed new EGR Pressure Sensing Module to clear CEL about 1 year ago. Has rough idle and lumpy crusing since. I found an un-plugged EGR valve hose, which made it run worse after plugged in. Changed the following:
1) New plugs,
2) New Mass Air Flow Module,
3) New coil pack,
4) New EGR Pressure Sensing Module,
5) New EGR Valve,
Disconnected battery for >30 minutes to reset PCM.
Still runs rough. Runs better, but not perfect when EGR Valve hose is disconnected from top of EGR.
Recently, 1 freeze plug leaking badly, replaced, then next day, blown head gasket. 1 quart of Blue Devil sealer fixed head gasket, as least temporarily. Not sure if these were related but posting just in case.
Scanner codes listed possible reasons for all things replaced above, plus O2 sensors, plug wires. Before I spend more $$, any thoughts for continued problems? Have read many threads here and some suggest that I need a new intake gaskets? I just hate those stupid mandated state car inspections, as it was perfect before inspecting it!
Could you give me the *specific* codes?
If they were P0171 and P0173 (I believe they are the ones, off the top of my head), it means "lean condition", and basically just indicates that more air is getting into the engine than what's measured by the MAF. At least on '98's, the main issure here would be the upper and lower intake gaskets. I can't remember if it was '00 or '01 that got a one-piece intake. If you got a separate upper and lower intake, then those gaskets could be the issue. However, it could be *any* vacuum leak.
A lean condition can also mean that it's having issues injecting the fuel, which can be bad injectors, clogged fuel filter, or a pump having issues.
O2 sensors and MAF sensor replacements assume that the computer is wrong in it's claims, but then you wouldn't have a horrible idle.
Disconnecting the EGR hose means that exhaust gas won't be routed back to the intake - this eases idle. (The entire idea of this is to help reduce emissions, and "lower the combustion temperature". Long story short, exhaust gas doesn't burn well.)
It also allows for another "leak", as it can suck air through the hose, without going through the MAF, meaning it won't "regulate down". This easing idle, could mean that you got a rich condition. If holding the tip of the EGR hose (to shut it off, and avoid the leak) means that it goes back to rough, it's the leaking vacuum that helps, and you may have a rich condition. If that doesn't change anything, what helps is exhaust gas not being rerouted. This could mean a lot of things, an example being high pressure on the exhaust manifold - something a clogged cat could result in. The high pressure would then force more exhaust back through the EGR valve, meaning more exhaust into the intake. Once again, there's a reason we use fresh air, and not exhaust gas, as our main intake.
Based on what you state (Rough idle, coughs at any load), I'd guess that some of the following could be true:
- Ignition and injection system
- - You changed the coil pack and plugs. The only thing left for ignition, would be wires, which I personally would have taken after plugs, if I speculated about ignition issues.
- - For injection, check the fuel filter, fuel pump pressure (Does it squirt fuel?), and injectors. Try giving it some injector cleaning additive. A big squirt of it.
- Leak
- - A vacuum leak is often followed by rough and high idle. If it's a gasket, it can be recognized by oil leaks (your engine consumes oil). If disconnecting the MAF results in more smooth (often in a bit higher as well) idle, this is often the case. In normal cases, disconnecting the MAF should case the idle to get rougher, or even die out completely.
- Sensors
- - The following sensors are related to the closed loop feedback system: Mass Air-flow sensor, Idle air temperature sensor (not the most important sensor), and O2 sensors. Mass air flow and idle air temperature sensors provide the main feedback about how much air goes into the engine, the O2/lamdba sensors are used to figure out how clean the engine burns, and can provide feedback about rich and lean conditions unnoticed by the system. All these sensors can be cleaned, using a swab, some lab alcohol (denaturalised alcohol, iso-propyl alcohol, whatever.), and a steady hand.
- Exhaust
- - The EGR valve being stuck can cause too much exhaust to be routed into the engine, causing it to choke up. This shouldn't be the case, as you replaced it.
- - Your cats could be clogged up. This is often noticed as a significant reduce in engine performance, as well as the ability to create white clouds behind you when you kick it.
- Intake
- - If it was only rough idle, your idle air control could've been stuck/defect. You could also have a leak in the vacuum control (a vacuum triggered swing-door style valve...thingie. It's the vacuum actuator on the top of the block, right behind the IAC)
Depending on whether you would say you're experiencing rich (generally rough driving, "choking" on higher loads, and no better idle when disconnecting the maf), or lean (better idle when maf disconnected, rough/swinging between suicidally low and extremely high idle), I'd go through different paths.
I'd check ignition, injection and check for clogs if I had a rich/coughing issue, and check the intake, look for leaks and check the idle air control systems if I had a suicidal idle/lean condition.
I hope this was helpful, and not just as confusing as I suspect it to have been.
- Leak
- Sensors
- Exhaust
- Intake
Joushou, thank you so much for such an incredible reply to my post! You've given me a other things to check out as soon as I can. I already have a new gas filter which I plan to install soon.
The codes were:
P171 (Fuel trim bank 1 condition), P174 (Fuel trim bank 2 condition), P303 (Cyl 3 misfire), P305 (Cyl 5 misfire), and P402 (EGR, which was replaced with a new one). I'll check the things you listed, meanwhile do you think, given these codes above, any other suggestions? Thx so much Joushou!
The codes were:
P0171 means lean condition in bank one, P0174 same for bank 2. This means that either you're getting too much air, or too little fuel. Vacuum leak would only cause a misfire if you drop into very low idle, cough, and recover, which is possible. Otherwise, it would be related to lack of fuel, lack of ignition, or maybe too much exhaust being rerouted (clogged cat). A clogged cat basically kills the engine.
Anyway, it's hard to tell much from those codes, apart from "somethings wrong". Follow the instructions I gave you - You should be able to figure something out based on it.
Pull off each of your plug caps, one at a time, and make ABSOLUTELY sure that when you re connect them, they seat fully/straight and you can feel they are clipped on the top of the plugs.
Trust me, I've chased a very similar problem for two days, only to find #3 plug cap was not seated properly.
BH
