Aupl8ed
- April 3, 2006
- Houston, TX
- '99 Explorer XLT
replaced alternator (salvage yard), replaced Battery. For three weeks the truck started fine..but as time went by you could tell it was getting weaker. You can watch the volt meter in the dash and see that it's charging sometimes and sometimes it isnt. I put a brand new volt meter to everything and I cannot find in reduction in voltage anywhere and I tested everything from a common ground. I guess my next step will be to replace the belt. Perhaps the fact that it's charging at time and not others is becuase the belt is slipping, though it seems plenty tight and there is NO noise comming from it no matter the RPM's. If you 'goose' it a bit from a dead stop, the volt meter in the dash will move up as though its charging, but as soon as you hit the next gear and the RPM's drop, the needle will drop significantly...nearly all the way down. However, even at 'dead' (no clicking, no attempt to turn over...nothing) windows and cd player, locks etc...still work and the very second I put cables on it to jump it..it will start...there is no 'charging time'..it starts immediately and will run for as long as you like. Turn it off and it may start again...it may not. There IS NO METHOD TO THE MADNESS! It's driving me nuts. Does ANYONE have a clue where to look next?
