Spartan
- September 24, 2009
- Sun Prairie WI
- 1996 XLT, 5.0 2WD
ALRIGHT
I have searched and searched, but have found NO answer to my question.
My Explorer is a 1996 XLT, 5.0. It had the dual power seats, with the adjustable bolsters, power lumbar, and slide out thigh support. They are beat to hell. I want to swap a set of 2000 Limited leather seats into my truck.
The seats have heaters and memory function. i do not care to have the memory function or the heaters hooked up. My connection under the seat in the 96 is a grey, two wire hook up (power and ground). What i need to know, is CAN i just hook up power and ground to these seats and make them function? If so, how do i hook this up? Ive read through all the swap threads i can, and still do not know if this is possible.
On a side note, i have a set of seats (just seats, not tracks) out of a limited. The connectors on the seat side are all different, with the exception of the large connector from the seat switch (plugs into the 96 harness). I can hook up the 96 harness to the main switch on the limited seat, and then the 96 harness back to the floor. The seat motors will run when the switches are moved, but the seat track itself does NOT move. The motors whirr, and the seat track doesn't move. This is VERY strange, since the tracks have never ONCE failed to move when the switches were actuated, up to and including when i moved them to get at the bolts holding them to the floor.
Any ideas or direction here?
HELP! lol
HELP! lol
