I have a 2000 sport w/sohc 4.0 v6. 12,800 miles on it as of this week. Had a problem noticing a shutter after starting and driving about 5 minutes. The night before I brought the vehicle into Ford, the truck acted like it was having a stroke. Started to do it's usual shutter around 1800-2000 rpm's/30-35 mph, but then the power just dramatically dropped, the check engine light came on and I couln't go over 30 mph....I'm assuming this is the "limp mode". They supposably replaced the intake orings and updated the chain tensioners. Got the vehicle back seemed ok for a few days and had it happen again. Not as bad as the night before it went in, but like when I first started noticing it. It feels like holding it at 1800 rpms @30mph, it seems to loose power a bit, when you press down on the accelorator, it seems to hesitate until you back off and press it down again firmly, then the engine kicks up fine. What the hell is going on. I'm guessing such items as TPS, fuel pump, pressure regulator???? Maybe an engine misfire under load?? I just replaced the filter and cleaned the MAF. Any help would be soooo greatfully appreciated. I don't want to have to get rid of this truck and buy my new love.......2001 Lightning!!!!
