koda2000
- September 2, 2011
- x
The transmission in my '01 ST does two if strange things. It's done them for a couple of years now (but only over around 4,000 miles). I dropped the trans pan and replaced the filter and put in 4.5 qts of fresh Mercon V, but the oil is still very dirty, no indication of pinkness. I doubt the PO ever had the trans serviced in the 184k it had on it when I bought it. I added a drain plug so I could drain the oil again if that's advisable.This is what it does and I don't know if the 2 things are related. I don't believe they are.
1. Twice in the past year I've had the trans appear to disengage (act like it's in neutral). Both times this happened I was driving up a slight grade, then getting off the gas, coasting and then reapplying some throttle. After 1/2 a second it went back into gear and worked normally. Most times the trans works perfectly normally.
2. If I try to back up on a grade (or back up quickly) the transmission, I assume it's coming from the transmission, make a noise. It almost sounds like the gears are stripping, but it will back up the grade. I'm thinking maybe the reverse bad is slipping? When I backup now I try to be very gentle to avoid this noise.
