rm787
- December 25, 2013
- 2001 Ford Explorer Sport
Hello everyone,
I own a 2001 ford explorer sport suv that I recently purchased. The vehicle is a 2 wheel drive, powered from the rear wheels. Automatic transmission with a 6 cylinder motor.
I was changing the transmission fluid & filter earlier today, and while under the vehicle, I had wanted to check the differential fluid level. I do have a Hayes repair manual for the Ford Explorer, but it's not too helpful with certain things.
I have read some conflicting information on the internet about drain plugs and fill plugs on the rear differential, which is why I wanted to ask about it here.
After checking out the backside of rear differential bell housing, I came across one plug that could be removed. It's a plug that faces the front of the vehicle, and it's about halfway up the differential housing. It can be removed by inserting a 3/8 extension into it, and of course turning it with a 3/8 ratchet.
My question is, for those who are familiar with the 2001 ford explorer sport that has the 2 wheel drive...is there only one plug on the rear differential? I could not find any other plug besides the one I located. I have seen other discussions on the ford explorer where it has been mentioned that there are two plugs on rear differentials (a lower drain and an smaller plug above it for filling) but I only located one plug on the rear differential on my Ford Explorer. I was just curious since...if it is a fill plug...I thought it would have been positioned higher up the bell housing than at the mid-point of the differential?
thanks
thanks
