sport trac jr.
- August 9, 2020
- P
- 2001 sport trac
2001 Sport Trac 5 speed manual I have now . Try to re-up on this ...the 302's are P VIN 1999-2001 seeing them dirt cheap....
Question I do need to get the 302 wiring harness and find one with manual trans.? and the manual ECU in donor car also?
or will the 2001 manual ECU work on the 1999-2001 302 engine non manual pull? If I get the wiring harness it has to be from
a manual original 302 harness....???
2. What manual trans goes with the 302 1999-2001...........???? and would that be a manual trans would have the fire wall
mount master clutch cylinder and out side slave???? And that might be a issue on the fire wall master cylinder....for mounting it
on the fire wall and if their is room?? I suppose a 5 speed mustang or explorer??? is the explorer rare the manual trans???
What other 2001 Sport Trac 5 speed manual items may their be and ...the exhaust system ......???? forgot...
thanks
thanks
