STinHI
- April 12, 2004
- Kealakekua, HI
- 2001 Sport Trac
After searching the board for many hours I have come to the conclusion to replace my front bearings I need to buy a new hub assembly right? Is this all I need? Also does anyone know the size of the wheel hub retainer nut (spline nut). I already have my front end stripped, I'm just waiting on taking off the spline nut. After I take off the nut all I do is pull off the plate with the studs? or is this connected to the hub? Then I just replace them correct? Oh yea this is on my drivers side, I'm running 33's on 15x10's and a 4" lift so I guess this added to the premeture wear. Does anyone know where I can buy the hub assembly? As others have stated its over $300 locally. I checked at Napa, a local chain but haven't made the stop to Ford yet I'm assuming its gonna be around there. Can this task be accomplished by an avid mechanic? Should both side hubs be replaced at the same time? Thanks for any help.
