macknos94
- December 13, 2007
- Harrisburg, pa
- 2003 mountaineer premier
I'm only on my phone so if you want to add info add it no questions just info to remove all the replete
Engine mods:
4.6 2v: most 2v mustang parts will fit our v8
Basic mods:
Intake: k&n, DIY home depot intake
Exhaust: many different routes to go so I'm gonna say search
Throttle body: light mods(non-FI) 70mm works perfectly, heavy mods( forced induction or built motor) 75+mm, mustang tb will fit
E-fan: great mod to help remove some rotating mass from you engine.
Cams: many will not go this far in modding so I'm gonna say call a performance supplier.
Tuner: sct is one of the very best out there. Contact.... on this forum for prices and custom tunes.
Underdrive pulleys: they are a great add on but a no go if you draw a lot of power (system, compressor)
Many of these mods will also work for the 4.0
Wheels:
Factory wheel specs:
Size:16x7.5 and 17x7.5
Offset: +43or +45??????
Aftermarket:
Size:Any rim from 16s to 24s have been installed
Offset: it depends on rim width but +43 to -12 have been fitted so search and sharpen your math skills.
Tire size:
Stock height: 265/75 is the most common used with no rubbing.
3 inch Body lift: 265s to be safe but people have fit 285s with some trimming.
Btf spacers: 265s are recommended.
Body lift and btf spacers: 285s
Will add more info tomarrow
Is there anyway we can get this stuck?
Engine mods:
Basic mods:
Wheels:
Aftermarket:
Tire size:
