1Aauto
EF Vendor
- April 1, 2009
- mass
- 92 explorer
VISIT US HERE FOR GREAT PRICES 2002-2005 Ford Explorer Rear Shock and Spring Assembly Pair (Monroe Quick-Strut)
MONROE QUICK-STRUT® 171322 - QTY 2
This is a new MONROE shock and spring assembly PAIR.
Specifications:
Quantity: (2) Shock Assemblies
Side: LH (Driver) & RH (Passenger) Side
Vehicle Type: All Models
Engine Size: All
Drivetrain: All (AWD, 2WD, 4WD)
Built to strict quality control standards:
Quick and easy... remove and replace one piece! No need to take apart entire assembly. No need to compress coil springs. Do the complete job right the first time. Enhances the handling, safety and performance of your vehicle.
Includes the following preassembled components :
Upper Mount
Upper Spring Isolator
Upper Spring Seat
Coil Spring
Boot Kit
Lower Spring Isolator
Premium Shock
The revolutionary Monroe Quick-Strut unit is the first complete, ready-to-install replacement strut assembly available! Monroe Quick-Strut units include all the components required for strut replacement in a single, fully-assembled unit. They feature pre-assembled replacement upper mount, upper and lower spring isolators, upper spring seat, coil spring, boot kit, and a premium strut. This breakthrough design saves on installation time by eliminating having to disassemble components and compress the coil spring prior to installation. Each Quick-Strut assembly features application-engineered valving to optimize each vehicle's unique ride and handling characteristics.
In the past, replacing struts required specialized tools to compress, remove and transfer the spring. Our new strut and spring assemblies make this job much simpler for the do it yourself mechanic. This part comes pre-assembled. Jack up and support the vehicle with jack stands. Remove the wheel. Unbolt the top mounts and the bottom from the suspension and replace the whole unit. The large bottom bolts usually require an impact wrench and socket for removal. When reassembling, be sure to torque all nuts and bolts to their proper specifications. Do not use impact tools when reassembling.
VEHICLE FIT
2002-2005 Mercury Mountaineer Rear Shock and Spring Assembly Pair (Monroe Quick-Strut)
Specifications:
Engine Size: All
Upper Mount
Upper Spring Seat
Coil Spring
Boot Kit
Premium Shock
VEHICLE FIT
