Stupidscript
- January 2, 2009
- Los Angeles
- 2002 XLS
Hi! New to the forums, but been lurking for awhile. I can't find the answer to the following situation:
Bought 2002 Explorer from my brother. Nice.
It already had an aftermarket stereo (Sony xPlod) which sounded crappy ... at low volume, everything was static-y with bass and mid response cutting out. It was virtually unlistenable at any volume below 20. (!)
I pulled that unit and installed a new Dual unit and then a new Clarion unit. Both are nice units, but both sound the same as the Sony ... crappy at low volume. The sound is just as crappy for radio, CD, iPod and USB sources.
I got a new conversion plug to replace the old conversion plug. No effect on the crappy sound.
During the installation of the Clarion, I reached way back into the stereo hole and found another pair of factory wires connected to a large-ish jack cluster. None of the aftermarket stereos can accommodate this extra jack. The jack cluster looks like it could manage 12-16 wires (3 banks of holes) and it is almost the width and twice the height of the main stereo plug (both are black), but there are only two wires coming out of the back of it ... one black w/white stripe and one yellow-ish ... might not be yellow-ish, but it's a similar color ... I can't remember exactly, now. Anyway, there are only two wires ... not 8 or 2+RCA plug or anything like that.
I have been doing superficial searching for a factory amplifier, thinking that the crappy sound may be because not enough juice is getting to the speakers, however, unless I have to remove an entire interior quarter-panel, it doesn't look like there is any easy-to-find amplifier in this vehicle.
1) How can I verify whether there is a factory amp, and then where to find it to bypass it (I guess)?
2) If there's no factory amp, any thoughts on why the audio system sounds so crappy?
I did not see any available converter plugs that fit my configuration. I found several that had one primary plug with 12 wires (or whatever) and a secondary plug with 2 wires + 2 RCA plugs, but the secondary jacks all look way too small for my situation, and besides, I only have 2 wires in my extra jack, not enough to satisfy a 2+RCA plugs scenario.
Thanks in advance for your time in considering this issue.
