chicows18
- February 4, 2014
- San Francisco, CA
- 2002 Ford Explorer
So i have a 2002 explorer 4.0L. Originally the car turned off and would not start again. Pulled off the motor, bought the tools, bought the kit and replaced all the chains, guides and tensioners. Pulled the heads off and sent them to a machine shop and had them shaved and pressure tested to make sure the valves did not bend. Replaced everything according to threads, forums, videos, and the good old timing chain book. Put everything back together and started the car at which point there was a fairly loud knocking noise coming from it. Pulled the motor off again and checked the timing chains again and repeated the whole procedure. The only fault i found was the timing chain tensioner from the front crank to the jackshaft was beat up badly. Almost as if something was scraping against it. Ordered another one from the dealers and set it up again. Put the motor back on and now the knocking noise is quieter but still there. The engine also vibrates almost as if it was not firing up on all cylinders yet they are all good. Any ideas? I don't know what else to do. Im very handy when it comes to cars and can pretty much do anything and have a variety of tools to get the job done. By the way, the kit i bought from rockauto.com . I think it was the DNJ kit since mines has the balancer shaft. Any help would be appreciated.
