explorer mania
- January 28, 2011
- WARREN MI
Hello all glad to have found this site .need help i have a 2002 explorer with trans problem 5r55w.trans will not shift from 1-2 driving normal ,but if i let off the gas for a second at 20 mph it will shift fine. 2-3 gear fine 3-4 gear fine also overdrive seems only to kick in if i let off the gas completely. Check engine light is on code is p0757 solenoid b stuck on also o/d light flashing .im leaning towards changing the solenoid pack but not sure if that is the problem also tranny does not slip or make any odd noises. Any suggestions would be greatly appreciated .thanks for reading
