2002 Ford Explorer Sports Trac | Ford Explorer Forums
mlgolfio
2002 ford explorer sports
What is the wiring order from sprak plugs to Ignition Cyl.?
Check engine light is on. The original code was for bad EGR value. The value was replaced but check engine light kept coming on with bad EGR value. Changed sprak plugs and wires. Then engine begin to idle and run rough.
Now I'm getting the following codes P1400, P0174, P0302, P0304, P0305, P0306, P0316, Inc., Catlyst, Evap., O2 Snsr, O2 Htr, ready Misfire, fuel, comp, EGR.
Any help would be great.
MLGOLFIO you need to post that exact same thread to mysporttrac.com you have some of the best knowledge available. it is the greatest site around
Big Johnson
