2002 Ford Explorer Window Issues | Ford Explorer Forums
Neffer319
McKees Rocks, Pennsylvania
2002 Ford Explorer
Hi everyone, I have a 2002 Explorer XLT, the other day all of a sudden none of my window would go up or down. i checked the fuse # 17 it was fine. After I plugged it back in the windows went up. Next day I came out and they didn't work again, once again i pulled the # 17 fuse and they worked again. I changed out the battery saver relay and the delayed accessory relay and the problem still exists. Any ideas.
Thank you in advance
In the door? And thank you, it is driving me insane
Welcome aboard!! :salute:
I had similar electrical issues with my 02 xlt. The dome lights would stay on until the battery saver feature turned them off, the accessory delay wasn't working, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, the delayed accessories didn't work, etc. The alarm would beep twice when I armed it. Recently all 4 windows stopped working. Most recently the driver door lock actuator stopped working.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 3 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal. When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ. I had to repair the pink/black wire to fix the driver door lock actuator.
Here is the thread for removing the door panel: http://www.explorerforum.com/forums//showthread.php?t=303524
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums//showthread.php?t=270081
Be sure to take your time when looking for broken/damaged wire(s). Check all the wires for breaks/damage. When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
If all else fails, here is a great link for troubleshooting the power windows, thanks to theofam for this great link Dead Link Removed I have this downloaded and can send it upon request.
Hope this helps out. :D:thumbsup:
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
