Its good to hear someone was able to do it. I tried but failed, got it down to one hub bolt that wouldn't turn rusted. Might have something to do with living in a great salt state. I was using a 15mm deep well and air gun and i got the bolt about halfway then nothing either way. Put it all back and took it in $100 and 30min later the guy is done. . .Can i ask a couple of questions?
How do you get the bearing bolts out, the CV joint was in the way? I spent like 1 hour on those alone. Getting there only took 10min
Once the bolts are out how did you get the hub out? Mine seemed welded in with rust.
the original problem ABS light coming on intermittently, STILL ON, so my next guess is do the right front, I might try again, but its expected to be in teen's and snow next week. . .so maybe not.
