very simple...
Programming remote transmitters
It is necessary to have all (maximum of four — original and/or new) of
your remote transmitters available prior to beginning this procedure.
To program the transmitters yourself:
² Insert a key in the ignition and
turn from 1 (LOCK) to 3 (ON)
and cycle between 1 (LOCK) and
3 (ON) eight times in rapid
succession (within 10 seconds)
with the eighth turn ending in the
3 (ON) position. The doors will
lock/unlock to confirm that
programming mode has been
entered.
² Within 20 seconds, program a remote transmitter by pressing any
button on a transmitter. The doors will lock/unlock to confirm that the
remote transmitter has been programmed. (If more than 20 seconds
pass before pressing a remote transmitter button, the programming
mode will exit and the procedure will have to be repeated.)
² Repeat the previous step to program additional remote transmitters.
The doors will lock/unlock to confirm that each remote transmitter has
been programmed.
² When you have completed programming the remote transmitters, turn
the ignition to 1 (LOCK) or wait 20 seconds. Again the doors will
lock/unlock to confirm programming has been completed.
Illuminated entry
The interior lamps illuminate when the remote entry system is used to
unlock the door(s).
The system automatically turns off after 25 seconds or when the ignition
is turned to the ON or ACC position. The dome lamp control (if
equipped) must not be set to the OFF position for the illuminated entry
system to operate.
The inside lights will not turn off if:
² they have been turned on with the dimmer control, or
² any door is open.
4
3
2
Controls and features
93
The battery saver will shut off the interior lamps 10 minutes after the
ignition has been turned to the OFF position.
AUTOLOCK (IF EQUIPPED)
The autolock feature will lock all of the vehicle doors when:
² all doors are closed
² the engine is running and
² you shift into any gear putting the vehicle in motion
The autolock feature repeats when:
² any door, liftgate or liftgate window is opened then closed while the
² you put the vehicle in motion
DEACTIVATING/ACTIVATING POWER DOOR LOCK DISABLE
FEATURE
Steps 1–3 should be completed within 30 seconds.
1. Turn the ignition key to ON, then press the UNLOCK button 3 times.
2. Turn the ignition key to OFF, then press the UNLOCK button 3 times.
3. Turn the ignition key to ON, within five seconds press the UNLOCK
button 2 times then LOCK once.
The user should receive 2 horn chirps to indicate the system has been
disabled or 2 chirps followed by a honk to indicate the system has been
enabled.
Pressing the power door LOCK button two times again will turn the
feature ON if it was previously OFF, or OFF if it was previously ON.
Every two consecutive presses of the LOCK button after successfully
entering the configuration mode will change the enable/disable condition
of the feature.
Turn ignition to OFF to exit programming. A horn chirp will follow if the
feature state has been changed.
