rrgone and nascar heres what I did. The 02 has 142,000 on it. I did all the work myself. Yes the diff was brand new from ford, cost 1160.00. This was a complete assembly. Has ABS sensor and was even fillled with oil. Two shock struts from ford at 55.00 apeice. 2 wheel bearing at 70.00 apeice and 2 spring at 110.00 for the pair. These parts came from rockauto. I bought this vehicle new in May of 2001. One of the first ones. It has been a real challenge but I believe I'm good to go now. The reason I went with the new diff is that by the time you buy a ring and pinion,clutch pack kit,oil, oil additive,axel shaft seals and ABS sensor if your light is on like mine, you'll have over 600.00 in these parts and still haven't even touched the spidergears. Then you have to set the diff up properly and hope you did a good job. Being I do the work myself and the diff came with a 12 month 12k mile warranty, I figured it was a no brainer. Anybody has any question I'll be happy to answer them.
