jon-w9
- March 1, 2004
- Michigan
- 2002 Sport Trac
OK, so we are currently in the process of buying a 2k2 Sport-Trac, and I just had some general questions about the truck, and 4wd vehicles in general. I hope this is the correct area.
1) I have read and learned that either the Motorcraft or PureOne oil filters are the ones to use. As for oil, I typically use a synthetic blend in my cars. Would the 4X4 oils be recommended? This truck isn't expected to see much off-roading.
2) Extended Warranty: I a considering 2 plans, ExtraCARE and PremiumCARE. Extra covers most major items; Premium covers all of Extra, plus emissions, audio, and safety (air bag, ABS, etc). Now both warranties will probably have $100 deductible. Has anyone had emissions problems or abs sensor failure in their sport (-trac)?
3) With the premium sound, there is a small subwoofer behind the rear seats. Would replacing the stock speaker with an aftermarket one enhance the sound, or would replacing the whole sub/amp/box with new units be recommended. I will probably end up keeping the 6-disc in dash unit, partly because of the rear controls.
Any other things I should check and or do to help drivability, performance, or mileage would be appreciate. I did a search for sport trac, does most, if not all the information for the explorer sport also apply? Thanks again..
Jon
Jon
