Lorelei L
- August 26, 2016
- Sacramento CA
- 2003 Explorer
I think I might have more than one issue going on. A couple weeks ago my girlfriend & I were driving and the thing just died as we pulled away from a stop sign. Steered over to the curb, put it in park, turned the key off & tried to start it. All dash lights came on & went off as they should but it wouldn't even turn over. We were late for a concert so I just left it there & got a ride. Came back the next morning & it still wouldn't crank over. Opened the hood & had a look around for anything obvious. Checked everything in the power dist box, all looked good. Smacked the solenoid thingy on top of the fuel rail (pardon my terminology, I only know the basics) and just fyi I am an oldish female
. After I did that, I got back in to see if anything had changed. This time all the lights went off except the check fuel cap and then it cranked but no fire. Messed with the fuel cap & it fired up so I hurried my butt home (4 miles). Bought a new cap at AutoZone and all was good until yesterday. Luckily this time I was only 1/2 mile from home. Idling outside the store for less than 5 minutes and it just died again. Tried all the same things as the last time.
When the fuel cap light is not on, it won't even crank. Once that light stays on, it cranks but won't fire. My son used his 2002 X to push mine home where the tools are. Pulled off the air hose & shot some starting fluid into the throttle body & it started for a sec then died. Kept trying to start it & it finally stayed running so I pulled it into my driveway. My fuel filler neck was loose so I tightened those 3 screws on top by the cap. That was yesterday. Today I went out to check it and it fired right up.
I've been reading posts everywhere for 2 weeks and I'm more confused than when I started. I've been under that damn X from front to back checking hoses, connections, fuses, relays looking for anything out of the ordinary.
Any advice would be greatly appreciated. I'm afraid this damn X is going to strand me in the middle of bfe one of these days.
