shelbydog25
- January 5, 2008
- Winchester, VA
- 2004 Eddie Bauer
My cruise control went out. I checked the brake pressure switch (brake lights on/off as supposed to be by pressing/depressing brake peddle), No ABS light on, no cruise control light on dash either.
I have read many posts on this sight on the issue, it sounds like the brake repair kit is an easy fix, however, my 2004 does not have a pressure switch next to the master brake cylinder. ??? model year change by ford?
Can someone point me in the right direction as to where the (of if) the 04 has the master cylinder brake switch ? and were it's located. Forgot to mention, horn works so the clock spring should be ok..
