dlclayton426
- September 2, 2021
- Hurdle mills, NC
- 2004 explorer limited 4.0
Hey guys im new to this whole forum thing but i am at my whits end with this truck so i recently swaped the motor out in my explorer the old one had timing chain failure so i bought one from a junk yard and installed it started it up was running pretty good had a small tremor so i tuned it up (plugs wires, fuel filter, air filter) with no change then finally the check engine light came on and i had p0300, p0301, p0302, p0303, p0316, p0174 p0401 i have checked for vacuum leaks sprayed entire intake with brake cleaner with no luck finding a leak anywhere any help would be greatly appricated also bank 2 fuel trim is pegged at 25 on idle and bank 1 is around negitive 12 or so i cant figure out what would make one side of the engine run rich and the other side lean??????
