dl011
- March 8, 2010
- nottingham, pa
i am having a heater / air condition problem. when i turn the heater on it works but i can not change the heat "intensity" (how hot the air coming out of the vents is). when i turn the knob the heat setting stays the same. when i put it on a/c it stays the same. just heat all the time. i can change what vents the heat comes out of and how fast it comes out but not the heat "intensity". i checked fuses in the engine bay and all were good. i got another heater control panel from a different explorer at a salvage yard and it did the same (dont know that it was good, but all other controls worked). could this be a bad or stuck relay somewhere? if so where can i find it? could it be a vaacum hose off somewhere. if so where is it? any help would be appreciated
thanks dan
thanks dan
