Exploder141
- May 28, 2014
- 2004 Explorer
Hi Everyone,
I'm getting noises coming from the rear of a 2004, almost positive it is the rear differential but I guess it's possible it's coming from somewhere else in the back. It has almost 100k miles on it right now and probably never taken off road.
It has light-moderate whirrs, howl and groans for the last couple of months. It seems to be getting progressively louder. The sound starts around 10-15 mph, only when the accelerator is depressed, never any noise when purely coasting. Sound is now present at all speeds when on the gas pedal after 10-15 mph. It doesn't make any noises when turning. Also makes a fairly light whirring noise when decelerating. At higher speeds the noise becomes more high pitched and howly, more growly at low speeds. At this point can still be drowned out with the radio.
I changed the differential oil just now and it was a brownish color. Didn't notice any large pieces or anything unusual on the gears from what I could see from the drain plug (which isn't much of course). There were however tiny silverish specs (no huge specs, like small glitter sized) in the differential fluid. There was any of these tiny specs that it might a couple of light streaks in the fluid. It had 75w90 in it originally. Put in 80% Royal Purple 75w140 synthetic in there, and about 20% Lucas Heavy Oil Stabilizer to thicken it up slightly more. The noise is still there, maybe improved very slightly but hard to tell.
Anyone have any ideas what my problem is here? Almost positive its my rear diff wearing out, but what specifically is it? Is it worth rebuilding or can I probably ride on it for years until it fails? Is there another diff fluid worth trying? Maybe Redline Shockproof? How many hours of labor are involved in a diff swap?
Any advice here is really appreciated. My funds are pretty limited now so I really need to work out how to best deal with this.
Thanks
Thanks
