scotty7676
- November 11, 2007
- FL
- 2011 Explorer Limited
I have been searching trying to figure out how to change the rear end fluid in my 2004 XLS. I think it has a limited slip due to the grinding noise it makes around turns, and wanted to change the fluid to see if that helps. I found two plugs on the diff cover. Ones a huge one which is the drain I'm sure, and there is one above it that I am assuming is the fill plug. Both are facing the rear of the vehicle and are located in the cover. I have two questions.
1. What the heck size is that drain plug square? Where do I find a tool to fit that?
2. Is that really the fill plug above the drain on the cover? I took it out and fluid started pouring out.
Thanks!
Thanks!
