alwayssmiling67
- January 12, 2004
- West Central Illinois
- 91 xlt
www.rorp.com
300 more acres of trails for 4wd vehicles just added!
Anc check out this exteme rockcrawling info:
Rockport Off-Road Park will host three Extreme Rock crawling events in 2004. The dates are March 27th and 28th, June 26th and 27th and Sept. 25th and 26th. Class One will be stock, class Two will be modified stock . There is a possibility of an open class being added for the second and third events if there is enough interest. There will be a limit of 15 vehicles per class. Each event will consist of two days that will start on Sat. at 7:00 a.m. for tech. inspection. You must sign up two weeks before the event dates to insure a spot.
There will be a point chase series for all three events; you must participate in all events to be qualified for series champion (least amount of points for three events.) In the case that an open class is added, you must participate in two events to qualify for series champion. There will a 100 % payback per event, top three spots in each class, $100.00 entry for stock, $150.00 entry for modified stock. Series champion pay will be determined by sponsor monies.
This event is divided into three stages, with each stage being more difficult, and a special stage in case of a tie. There will be 3 judges per stage, and two marshals for the event. Judges will decide how points are given. Flags will be set up as gates and caution tape as boundaries throughout the three stages. This will be a timed event.
Vehicles in stock class must have current license plates, proof of insurance, street legal, have front and rear lockers, working winch, full roll cage on open top rigs, and all recommended safety equipment. (Seat belts, fire extinguisher, tree saver, leather gloves, first aid kit, winch weight if using steel cable.)
Drivers can and should have one spotter or co-driver. Competitors must wear seat belts at all times when in the vehicle.
Any participant deemed under the influence of alcohol or drugs or having ANY alcohol container in their vehicle will be immediately disqualified.
Class one will be stock. Rules- Vehicles of O.E.M. style body, frame and suspension. Flat front fenders, and minor body trimming allowed, body must be factory width. Frame can be no shorter than leading or trailing edge of tires. A maximum of a 4 inch suspension lift, stock style springs, no Revolver shackles, no quarter elliptical springs, no buggie springs, no coil over shocks, no long arm bars, no air bags, no spring over axel if not factory style, no coil springs if not factory style springs ,factory suspension mounting points no more than 2” over stock , shackle reversal approved for leaf springs,3” body lift max, hydraulic assisted stock steering approved, must meet state and local laws for lights and current license plates, must have front and rear lockers, working winch, roll cage on open top rigs that will protect the driver, seat belts, fire extinguisher, first aid kit, tree saver, leather gloves, winch weight if using steel cable. 35” tires, as advertised on the sidewall. Overall wheelbase must remain +/- 2.5” of stock, with a width of no more than 96”outside of tires.
Class two will be modified stock. Rules- Vehicles must retain factory grill, hood, firewall, body and frame must be of stock origin for the year of the vehicle, frame can be aftermarket OEM design that meets stock specifications(only rectangle tube), at least to the axel center line, plating for strength or repair accepted, full cage to the frame that protects driver on open top vehicles, wheelbase of no more than 115”, with a width of no more than 98”outside of tires, must have front and rear lockers, working winch, seat belts, fire extinguisher, first aid kit, tree saver, leather gloves, winch weight if using steel cable, any suspension upgrades, hydraulic steering accepted, no rear steer, 39.5” tires, as advertised on the sidewall, 3” body lift max.
If there is enough interest and response: Class three will be the open class. Rules- Maximum tire size of 39.5” and all vehicle safety requirements (working winch, seat belts, fire extinguisher, first aid kit, tree saver, leather gloves, winch weight if using steel cable, and full cage to the frame that protects the driver)
We will use a point system, series points follow the driver, driver and spotter are not allowed to switch places, different spotters are allowed for each event, with each driver starting the stage with 0 points. Max points of 50 for each stage for class one, 40 points for class two. Max time limits of 16 minutes per stage for class one, and a max time limit of 12 minutes per stage for class two. If you reach max points or max time, you will be finished for that stage. Bypassing a stage or no show: A team that chooses to completely bypass an obstacle or complete stage, or does not show up for the 3 minute call, will receive 50 points, a team that places two tires of the vehicle through the start gate to time out will receive 40 points instead of 50 for no show.
If you break, you will have 45 minutes of cumulative Breakdown-Time per day of the competition. Once the 45 minutes is exceeded, that team is disqualified for the day and receives50 points for each remaining stage.
For more information or to sign up for the competition please email parkinfo@rockportoffroadpark.com
