2005 Adrenalin was running now won't start | Ford Explorer Forums
Dan308
Albuquerque
2002 Ford Explorer Sport
Help me find this part. I replaced it with a Doorman 590-001. Is this the right part? 2005 ford explorer Adrenalin sport trac 4x2
Truck was running fine when parked but would not start when I got back in it. Cranks but will not start
Inertia switch - checked
Battery - new
Alternator - new
Spark plugs - new
All fuses & Relays - checked
Fuel rail sensor - replaced
Fuel pump - replaced
Fuel pump driver module - replaced
Crankshaft pos sensor - replaced
Gets Spark
The theft light
Does it go off when cranking the starter?
Check engine light
Does it go off when cranking?
Check for spark
The theft light
Check engine light
Check for spark
yes lights go off, will check again for spark and report back
Okay this is good
The theft light going off while cranking generally means the security system is happy with your key
The check engine light going off while cranking means your pcm is powered up and it is seeing a signal from the crank sensor when the engine rotates
Now it’s time to test for fuel pressure and for spark
The last test would be compression, looking for any signs that this engine may have jumped time
The 05 sport trac I love them, they are beautiful, last year if a great platform.. but the 05’has some crappy one year parts. The instrument cluster is part of the computer system and it is the only instrument cluster like itself… 05 trac only.
They also use a fuel pump driver module as you know and a one year pcm to control everything. That kinda stinks especially when they do this and won’t start
So the basics, fuel spark air
That’s how we test without buying parts
Okay this is good
Checked and I do have spark
Changed crank pos sensor and NO start
I forgot to add, I put in a new cluster that was from a sport trac made the same week on the same assembly line. No change
So fuel pressure? Is the pump coming on?
If you have adequate fuel pressure then it is time for a compression test
To make sure the engine has not jumped time
used starter fluid and no start
