muddydan
- December 20, 2009
- Saline County Missouri
- 05 Ex
2005 Ford Explorer 4 DR XLT MPV 4X4
4.0L SOHC 5R55S Automatic
About 2 months ago my ex had a bad burning smell after a run in with some ice. It came up with two codes
:thumbdwn
0720 Output Shaft Speed (OSS) Sensor Circuit
:thumbdwn
0722 Output Shaft Speed (OSS) Sensor Circuit No Signal
:thumbdwn:Slips in M1, M2, D. Reverse and 3rd gear work(I was told this is FMEM mode)
We ruled all internal transmission problems. I went through the entire transmission wiring harness(7C078) which has PCM 175-t connector at one end. All wires in the entire harness, including connectors, ohmed within suggested resistance. *most were .3ohms or less* The sensor was switched with a new sensor and also placed in position of the ISS and TSS to verify working condition, sensors are fine. We also went through a diagnose by symptom and TJ pinpoint test on Ford tech service. PID test also shows OSS(RPMS) reading when vehicle is in gear with brakes applied.
All I can think of is that the PCM needs to be replaced. Maybe the computer read to much resistance in the circuit and may have fried a processor in the PCM? Any input would be helpful
:thumbdwn
:thumbdwn
