blakusta
- September 30, 2012
- Calgary
- 2007 Ford Explorer XLT
so when the explorer is in idle, the rpms bounce causing the entire vehicle to shake a bit. When i look at the engine under the hood, the engine moves every time this happens. I have changed the plugs recently. It has 178 000km on it now. it sounds as though there is a air leak under car, on passenger side near the transmission, but I can't find anything leaking. I have also had a few issues where the car seems like the transmission will not shift, and it just kind of sputters. I have checked everywhere under the hood, I even tried cleaning the throttle body for the sputter. If anyone has a vacuum line diagram on here maybe that would help, or any other suggestions!!!
