2007 Front Hub Replacement | Ford Explorer Forums
weberman
07 Explorer Sportrac XLS
New member!
I am from S.W Florida and have a 2007 Ford Explorer Sport Trac XLS V6 with about 110,000 miles.
I found this site and it is a great source of information. My Sport Trac is getting to the point where repairs will be more frequent and I can't afford dealer prices. I am pretty good at mechanics.
I need to replace the Left Front Hub. Kind of hard to even find a repair manual.
I was searching here in the Sport Trac forum but could not find any info on replacing the Front Hubs. There is, however, information in the 2006-2010 Explorer/Mountaineer forum.
My question is, is the Sport Trac hub replacement the same as the Explorer?
If not any help or directions would be appreciated.
Thanks to all.
Web :)
They are the same. Check out the third gen explorer forum, there is a good guide in there that I used to do mine. Make sure you get the torque right on the shaft bolt. Too loose or too tight will cause a premature failure of your replacement.
Thank You!
Thank You!
I thought so but wanted to be sure!
Now, Can go forward with some assurance.
Web :)
