2007 Sport Trac won't start | Ford Explorer Forums - Serious Explorations
stevemp
2007 Explorer Sport Trac
The engine cranks fine. I am thinking fuel delivery, probably the fuel pump.
Are there common causes for this issue? Is it likely the pump? I checked the fuse and relay and they are fine. I also checked the reset switch. Is there anything else I should check before I assume it's the fuel pump?
Someone suggested to me that there may be a control module of some sort, is that true?
Thanks,
Steve
When it happened on mine I had to hit the reset switch a bunch of times. Try it with the key On too. In my case my son accidentally kicked it with his size 13's.
It may be mass airflow sensor. They have tendency to crack. Had to replace mine at 90K
Well it turned out to be the fuel pump control module. It had rotted through and was caked with salt on the inside. Don;t you love winter? ;-)
