steve6534
- February 25, 2003
- Southern NJ
- '06 EB V8
My 2007 explorer limited takes this one step further - the drivers power seat moves back unexpectedly. I'm almost certain this is an ignition problem, as some other posts suggest as I have wiggled the key when seated in the ignition which triggers the symptom. Does anyone know if there is a safety recall for this issue? it's particularly frightening when a shorter person is driving and in the process of stopping, which can pull the foot off the brake pedal. Scary since this is my 5'1" wife's daily driver.
I haven't heard of a recall but you can at least turn off the auto adjustment by disabling "easy entry" in the dashboard menu. I'm certain it's a short in the ignition switch causing the problem too.
